hi sg, That linked module, you posted, should get the job done. E
ericgibbs Joined Jan 29, 2010 21,622 Jan 13, 2023 #41 hi sg, That linked module, you posted, should get the job done. E Last edited: Jan 13, 2023
Thread Starter memedin Joined Dec 24, 2022 30 Jan 13, 2023 #42 sghioto said: https://www.amazon.com/Current-Voltage-Converter-Module-Non-Isolated/dp/B07VTRVD75 Click to expand... it has lm324 on it
Thread Starter memedin Joined Dec 24, 2022 30 Jan 13, 2023 #44 ericgibbs said: hi M, The LM324 is not a problem. E Click to expand... ı understoo thank you
S sghioto Joined Dec 31, 2017 8,758 Jan 13, 2023 #45 The XTR110 would have been the correct chip in this application, shown wired for 0 to 5 volt input and 4 to 20ma output.
ericgibbs Joined Jan 29, 2010 21,622 Jan 14, 2023 #46 hi @sghioto @memedin Based on the image post #45, this is a rough approximation of the circuit in LTSpice. This draft circuit looks promising. E Attachments XTR101_Sensor1.asc 3.4 KB Views: 2 Last edited: Jan 14, 2023
Thread Starter memedin Joined Dec 24, 2022 30 Jan 14, 2023 #47 Hi, @sghioto @ericgibbs First of all, thank you for being so interested in my problem. Now I have started a drawing with XTR101, I will throw it to you.
