Problem with Universal Motor Control Using a TRIAC
mhm_004
Joined Sep 3, 2017
I have used the following circuit to control a washing machine universal motor. The problem is that after some time, the resistors in the optotriac-to-TRIAC drive path, namely R29 and R30, start to burn out, especially R29.
I have attached the datasheets for these resistors:
  • 100Ω: SR2512JK-07100RL
  • 220Ω: AS122WJ0221T4E
I have also attached the voltage waveform measured across R29.
So far, this issue has only occurred on one board that had been running under test for a few days. However, I am concerned that there might be an underlying design issue that could eventually affect other boards as well.
The circuit is based on STMicroelectronics Application Note AN5114.
I would appreciate any advice from those who have experience with this type of circuit. In particular, I would like to understand why the 100Ω resistor (R29) might be burning out.
Any ideas or suggestions would be greatly appreciated.
Thank you!
