I've made a couple of kinda video's already on YouTube.With the frame on wheels like that and the way the welds look on the worm gear box brackets, please, please make a video of your first test bend. It will be a Youtube viral.
The best way i found to set up a carb is using the Propane Enrichment method. You need propane with a regulator and on/off valve and a port on the engine. You adjust the regulator for max rpm and turn off the propane. The RPM change needs to be small, like 25 RPM. This method assures the throttle plates are in the idle system.It has some carby teething issues that I need to get around to addressing...
Your correct when you say a mandrel bender has the internal "bullet" that's what makes them a mandrel bender. But even a mandrel bender uses a wiper block on the out side. all of the original links you gave showed a wiper bender, so called because they have a flat, straight block that has 1/2 of the tube outside diameter in on face. It's the wiper that is actually making the bend, not the mandrel. A manual copper tube/ brake line bender is a good example of how the wiper does the bend and keeps the tube from flattening too much on the outside of the radius of the bend.I am not sure what defines a mandrel bender other than it being a machine that employs that bullet shaped slug that runs inside the tube at approx the tangent point of the bend while being bent to ensure the wall integrity during the drawing/bending cycle.
Since the form I have mentioned is a half circle only, in one position it can be installed as you suggest, where the form rolls the tube around itself, however setup in the oppoiste senario and then the form will require the wiper stroke as you mention.
