How to use ground stitching and shielding?
Younes Thabet
Joined Jan 9, 2019
152
Hello guys,
I was wondering when ground stitching 2 ground layers, what kinda pattern and spacing I should follow to place vias? and should I use more vias near components/pads that dissipate more heat?
As for shielding, Is it only used in RF boards or it doesn't matter!!
And if someone can give all cases where stitching and shielding can be used? I will be very thankful.
Thanks,
Deleted member 115935
Joined Dec 31, 1969
Stitching has a few uses as you have indicated,
both very different
Thermal, is of use to move heat. !! They are close together, and at the source of heat. every few mm,
Ground stitching for EMI / EMC, is different.
first you want to ensure that there is no floating copper on top / bottom of the board. All un connected copper needs to be connected to something, normally ground, Much easier on multilayer boards, but always useful,
Then , its normal to ensure you have connected the grounds together every 10mm or so.
That is a bit variable, depends upon frequencies, components, but is a good starting point,
At the end of the day, unless you spend a few thousand on simulation software, its a bit of a best guess.
Younes Thabet
Joined Jan 9, 2019
152
its normal to ensure you have connected the grounds together every 10mm or so. That is a bit variable, depends upon frequencies, components, but is a good starting point, At the end of the day, unless you spend a few thousand on simulation software, its a bit of a best guess.
Then, I could use 10mm spacing between vias as a start, right!!..
So 10mm is just a guess and this kinda things require simulation for better results !!!
could you provide some examples/explanation as for when frequencies and components could affect EMI/EMC!! and how stitching could prevent that?
Joined Dec 31, 1969
yes 10mm is a good start
If you want to start reading up , EMC / EMI a big field,
these guys have IMHO a good course, and some free bits
http://learnemc.com/
and
http://www.compliance-club.com/archive/old_archive/980814.html
https://www.amazon.co.uk/High-Speed-Digital-Design-Semiconductor/dp/0133957241
https://www.oreilly.com/library/view/high-speed-noise-and/9780134580685/
