Will a ferrite aerial be affected by being on a PCB with a ground plane?
bertus
Joined Apr 5, 2008
23,033
I have seen ferrite antennas on pcb's using plastic spacers, to keep the antenna about 1 cm above the pcb.
Bertus
Placing a ferrite rod antenna directly over a PCB ground plane often degrades its performance. A copper ground plane supports eddy currents induced by the antenna's magnetic field. These currents dissipate energy. The antenna's sensitivity becomes effected as a result.
