How to wind a ferrite cored transformer wihout bobbin?
cmpx
Joined Oct 23, 2021
60
Can somebody show me the pictures or a video how to wind magnet wire onto E20 transformer ferrite core without plastic bobbin?
ronsimpson
Joined Oct 7, 2019
4,811
It is next to impossible and not a good idea. I have winding machines that wind on bobbins. They will not wind directly on a core. The cores will scratch off the insulation. Cores will conduct at high voltage.
Wind the wire onto some block (from wood, plastic, whatever), probably 6x6mm. Then pull out the coil from this block carefully. Use enamel to fix the coil surface.
Then put the coil on core and fix with enamel.
35,170
Another idea is to wind the coil on any material on top of extended lengths of Kapton tape.
When you are finished winding the coil, remove the coil from the form and wrap the Kapton tape over the turns of the coil.
