Teensy Audio Board RevD Audio Out Ground Pin Connection "out gnd"
TonyAm
Joined Oct 12, 2022
87
Thanks for reading. The Teensy Audio Board RevD has an audio "out gnd". I am connecting a 10k Log Volume pot to the "L Out", then into a 1/4" audio output jack. Should the 1/4" output jack's gnd lug be connected to the "out gnd" also?
Sincere thanks.
TonyAm
Fonhuaicho
Joined Apr 10, 2026
6
Thanks for bringing this up. Small connection details like the “out gnd” pin can save a lot of troubleshooting time later. Audio grounding issues on the Teensy Audio Board RevD can easily introduce noise or unstable output if not wired correctly. Looking forward to seeing the discussion and final solution, this topic will definitely help others working on DIY audio projects with Teensy boards.
TonyAm
Joined Oct 12, 2022
87
Hello, Yes. I connected the OUT GND to the GND of the potentiometer and to the 1/4" audio output jack. I didn't connect it to the other GND's of the Teensy. As seen in the schematic. It is only used for audio out GND.
