Hello
First, not sure I`m posting in the right section. If not, can admin. move my posting.
O.K, I need advice. I am looking for a Small Audio circuit, run off of a 6v -12v battery source. It has to have a USB connector so it can be programmed with audio, max. 2 min. playback length. The circuit should be able to connect to a speaker and have output sound level adjustment manually. It should also be able to be set to repeat play that audio file till turned off.
This circuit has to be Small in size. 2-3 inches. I would like to install it in a Remote Control Boat for sound effects.
If anyone knows of one that works for my needs, Please include a link to it in your reply.
Thank You for your Time and Help.
