how to get the stable amplified output for strain gauge
ericgibbs
Joined Jan 29, 2010
21,628
eric,
i saw your simulation.. but this circuit did not satisfied the my another condition... for zero input output should be 4mA
hi,
To get 4mA for 0v input [330R at the bridge], you need to apply a offset voltage at the U1/2 inputs so that Vout=1 v for a 330R value]
So that Vinp to the V2I converter is 1V thru 5V, for 4mA to 20mA output, which is a common method.
E
rajitpk
Joined Jan 30, 2018
108
hi,
E
can you briefly explain it..? also is there anyoption to modified in U4 opamp side ( V-i converter circuit) to achive 4mA at zero output
ericgibbs
Joined Jan 29, 2010
21,628
hi,
There is an alternative method.
Adding a 2N3819 constant current source, to offset the Iout to4mA for a Vin of 0v.
Note that Vin will be from 0V thru 4V [ reduce the IA Gain]
E
rajitpk
Joined Jan 30, 2018
108
hi,
E
hi eric,
By same is there any another option to limit the 20mA current output at U4 opamp side( V-I converter). i will try zener diode method but i would be better if we modified it on V-I converter side. is there any possible...
ericgibbs
Joined Jan 29, 2010
21,628
hi rajit,
If you mean the simulation.?
I set the bridge R14 resistor to step in value from 330R to 331R in 0.1R increments.
For each increment in R14, the plot shows the Iout current from 4mA thru 20mA [limiting close to 20mA]
R18 is adjusted for Zero Vout when R14 =330R.
E
rajitpk
Joined Jan 30, 2018
108
hi rajit,
E
dear eric,
i have to change the R7 resistor value for 330 to 330.7 not in R14 and may i know the use of 47micro and 100n f capacitor?
is that any equivalent JFET is available to replace J1(2N3819)
ericgibbs
Joined Jan 29, 2010
21,628
hi,
It is a simple as swapping R7 and R14 on the bridge over, [also moving R18] this sim shows the result.
What type of n JFET's are you able to buy in your area.?
The 47uF and 100uF are required for power supply decoupling.
E
rajitpk
Joined Jan 30, 2018
108
hi,
E
okay eric.
i asked for same spec of J1. but there is not available exact spec? still now i search for same spec..
rajitpk
Joined Jan 30, 2018
108
hi j,
This is the 2N3819 datasheet.
E
EDIT:
Check this link for equivalent.
https://english.electronica-pt.com/components-cross-reference?ref=2N3819
dear eric,
finally i order the 2N3819 JFET. but delivery time is a week. is that need to replace the LM324( ampifier( U2,U4,U6) and V-I (U1,U3) coverter)ic with standard one to improve the circuit because i found one website in my country who are ready to deliver some standard components... can you suggests me?
DECELL
Joined Apr 23, 2018
96
I think this jfet thing is a red herring its thermal stability is not that great. Use smarter current summing see AD CN-0295:
rajitpk
Joined Jan 30, 2018
108
hi,
In post #32, you said you had the LM358 option, that is the OPA I have been using in the simulations, not the LM324
E
sorry eric... i used LM358 only
now i can have a option to use some standard.. is that really need to replace LM358 with other one or not?
ericgibbs
Joined Jan 29, 2010
21,628
hi rajit,
I do not know what types of OPA you can purchase in your area.?
Give me a short list list of OPA's that you can buy and I will try to select one from your list
E
