okay eric,hi,
Use this procedure,
Change R6 to 3k5 , this will increase the Gain.
1. Set R1 to 330R, increase the value of R3 to ~330.18R. [as you can see it is very small change in R3]
Vout should now read ~1V [ this is the base voltage which gives an Iout of 4mA]
2. Set R1 to 330.7R, Vout should read ~ 5V, so Iout should read =20mA
You may have to repeat from Step 1 around the loop until you get Vout =1V and 5V
Note: You could reduce R4 by a very small value instead of increasing R3 [ it may be easier, by adding a high value resistor]
E
i will work on it... i vary the R3 it will be easier one..
but is that any solution for my PCB board...
