ok so i bought 5 of the above modules from ali express, to use as a switch debouncer for 4017 led sequencer.
i have tried 5 different momentary tactile switches wired using 7/0.2 stranded hook up wire, about < 1 metre in length.
this is connected between the ground and trigger pin of the module.
all triggered eratically if at all, testing on a breadboard and using an led for output (with 1k resistor) but using a short single core wire ~5cm on the ground and trigger pin worked with no problem ???? tiggered every time on touching the wires.
adding a 1k resistor between the vcc (9v) and one side of the switch did not help matters.
any suggestions to make the module work with ~1m switch wires.
or
suggest a very simple debounce circuit that would work ?
thanks in anticipation
dave
or
dave
