The whole that instrumental amplifier thing is very crappy about resistor nominal values. If You can with an ease warranty that 1,0 kOhm ir no less than 0,999 and no more than 1,001 then all is OK, but if not - then You shall see all possible wonders from horror-tales. Therefore my advice is take the instrumental amplifier tablet from already ready-made, where everything except the gain resistor is inside, is laser-trimmed and work with a warranty.hi,
I use the MCP6002 series, they operate from a 5V supply and are rail to rail output.
The 6002 is a dual but there is also the MCP6001 single OPA, not too expensive.
E
