okay Ehi r,
That 1uF is part of the power supply decoupling, it should be on your actual circuit build, the LTSpice sim does not require it to work.
E
okay Ehi r,
E
hi E,hi rajit,
The circuit I posted should work OK, have you changed any other component values.
Can you post a clear photo of the circuit, so that I can check the build.?
Eric
EDIT:
I have tried many modifications to the circuit and I cannot get the results that you measure.
Check your 24V power rail and Rshunt supply connections.
UPDATE:
I assume that your 15V regulated supply to the Rshunt input is decoupled, also the 24V is decoupled.?
The 24V must only power the LM358's and the 15V for the Rshunt, only the shunt circuit.
Also the 24V and 15V Common 0v lines must be connected together.
no its different..Datasheets show both the CK100 and the CL100 as NPN devices. The output transistor should instead be a PNP transistor.
sorry eric.. i made mistake while drawing the circuit for my post...hi rajit,
In your circuit diagram the CK100 is upside down!, it that how it is wired in the circuit.?
Eric
okay eric....hi rijat,
I will look thru your circuit diagram. [will post back more info later]
As you are using LM358, they must have a higher supply voltage than the Rshunt voltage supply.
The LM358 is not specified to work with input voltages equal to its supply voltage.
So the Rshunt supply is 15Vreg.
Ideally the R15 resistor should be 250R, so that a 4mA current will produce a voltage drop of 1v and 20mA a 5V drop.
These voltage drops are compared with 1V thru 5V voltages being input from the bridge circuit, so that the output transistor Q2 outputs 4mA thru 20mA.
What is your bridge supply voltage and also what is the supply voltage to the LM358's in the bridge amp.?
E
but how can i get 1 V amplified output at balanced condition (R1 = 330)hi rijat,
E
okay eric...hi rijat,
I am looking over the circuit now, please give me time.
E
okay eric i will work on it....hi r,
I have run your circuit in LTSpice simulation, it works as expected.
I have set the Gain of the bridge amp to 1000, so 5mV from the bridge gives a Vout of 5V.
Inputting 0v to 5V to the V2I converter circuit gives 0mA thru 20mA.
Check thru the attached circuit.
E
