How do you identify ICs and other components on a circuits board
Errorbot1122
Joined Sep 5, 2020
So i'm currently trying to take parts out of a Bluetooth speaker's circuit-board and find the Bluetooth module for a DIY project.
A pic of a disassembled Bluetooth speaker
I looked at the board and some ICs and tried looking them up to no avail.
So How Do you read an IC or any other components on the board Or even find a schismatic of some-sorts!
dl324
Joined Mar 30, 2015
18,524
Through hole semiconductors will typically have a complete part number. Surface mount will use a code that you need to look up, and the codes aren't unique between manufacturers.
You start with the manufacturer. In the event that they won't provide one to discourage copying, you can trace the circuit and make a schematic. If there are unmarked components, you use connectivity to make an educated guess as to what it might be.
