Trying to identify some components 21n/21h, please help
Joined Sep 21, 2022
Hi!
The component marking is: 21h OR 21n
Case is TSSOP6 (SOT363): 2 x 1.25 mm
The manufacturer of the microchip is most likely NEXPERIA, since other logic microchips were identified by this manufacturer.
The function of the microcircuit or microassembly is to act as a buffer between the inverter and the gates of the mosfet switches, which in turn drive the primary winding of the power transformer.
A search for components in marking databases was unsuccessful.
Any help will be appreciated. Thanks!
ronsimpson
Joined Oct 7, 2019
4,888
I think it is a dual buffer or inverter. I cannot find that pinout. But I am certain there are two elements running in parallel.
link1 74LVC2G14GW or 04 or 06.
Joined Sep 21, 2022
Thanks, but control signal certanly goes to pin 2 & 5, in 74LVC2G14GW 2 & 5 pins are power suplly.
It is not 74LVC2G14GW.
