Ground triggered Latching Circuit using transistors
eetech00
Joined Jun 8, 2013
4,734
Can I use a 1N4004 diode across the relay coil instead of a 1N4148? Not sure what the difference is.
TONY
Actually, you should use 1N4004 instead of the 1N4148.
The 1N4148 is a switching diode designed for hi speed switching applications and has less current capacity than the 1N4148. The 1N4004, on the other hand, is slower, but has higher current capacity that is important when applied as a relay snubber. The collapsing magnetic field of the relay can reach high voltage levels, so use a diode like the 1N4004.
dl324
Joined Mar 30, 2015
18,479
Actually the 1N4148 was sufficient. The diode will be forward biased when the relay is switched off and it just needs to handle the current built up in the coil when it's switched. Coil is 320 ohms, so only draws about 40mA. 1N4148 can handle 200mA.
eetech00
Joined Jun 8, 2013
4,734
Back EMF is not the same as forward conduction. Its in the reverse direction and can reach hundreds of volts.
The 1N4004 (or 40005-4007) is better.
38,872
It's just the diode surge rating that has to equal the relay coil current as the diode only sees that current for a few tens of ms when the relay is turned off.
Thus, for example, the 1N4148 has a surge current rating of 1A for 1s, so it can be used for relay coil currents up to that value without a problem (unless perhaps the relay is being rapidly turned on and off several times a second).
And the diode across a relay coil only experiences a maximum voltage equal to the supply voltage. It doesn't see any high voltage from the collapsing field since it is providing a path for the current generated by the collapse, which limits the spike voltage to the forward drop of the diode.
dl324
Joined Mar 30, 2015
18,479
Back EMF will be limited to a diode drop above the positive supply. Peak current will be the current in the coil when it's switched off. The diode reverse voltage rating only needs to exceed the power supply.
38,872
You have a fundamental misunderstanding of the voltage generated by the inductive kick of a coil.
It's true it's in the reverse direction, but that's the forward direction of the diode across the coil, thus the voltage is limited to the forward drop of the diode.
The diode never sees any high reverse voltage.
eetech00
Joined Jun 8, 2013
4,734
Thanks for you input crutschow, but I was in the railroad control system design industry for many years, and I understand it clearly. We always used 1N400x diodes (actually 1N4005 back then) for back emf prevention.
I found a couple of demo videos. Have a look.
Anyway...just my recommendation.
stillgrowingup
Joined Jul 15, 2015
219
What's the total current draw for that incandescent bulb plus the relay and LED?
You'll need to make sure Q1 has enough base current to drive all of them.
Good catch. In the discrete design there was a small signal transistor to boost base drive for the power transistor. OP removed it and it's still needed. Power transistor load is about 300mA and the flip flop will only be able to provide a fraction of the required 30mA.
I'm using a T77V1D10-12 relay, SLL-LX3044ID-12V red led and a 2w 12v miniature bulb. Not sure of part number cause its preexisting.
What do I need to do?
Tony
dl324
Joined Mar 30, 2015
18,479
You don't get a large voltage spike when the relay is switched off unless you don't have a snubber diode. With the snubber diode, it never sees a large reverse voltage spike because the voltage polarity on the coil reverses when the field collapses and the diode is forward biased. The only reverse voltage the diode sees is the supply voltage when the relay isn't energized.
Using a component that greatly exceeds requirements shows a lack of understanding and finesse.
stillgrowingup
Joined Jul 15, 2015
219
It's called a Conversation here. Just started one with you...
Uploading to dropbox then I'll send you a link.
Do I need something else after this 4013 output, but before the BD139?
TONY
dl324
Joined Mar 30, 2015
18,479
You can do something like this to increase current gain:
EDIT: R1 should be 200 ohms. Or you can connect as a Darlington if the relay will tolerate the reduced voltage.
38,872
I'm afraid you don't.
And there's the old saw "We've always done it that way". :rolleyes:
