Flyback converter in power supply design
srihariraom
Joined Sep 27, 2021
14
What are the advantages of using a flyback converter in the power supply systems?
What are the complications that designer usually faces when flyback converter is used?
How is GaN based flyback converters different?
Regards,
Srihari Rao M
Papabravo
Joined Feb 24, 2006
22,111
These are the short answers.
Use of a transformer provides isolation between the input side and the output side.
Transformers are AC devices. You must ensure that no DC components can be allowed to accumulate.
Creating an isolated feedback signal for the control circuits.
They can work with much higher voltages and currents.
srihariraom
Joined Sep 27, 2021
14
I am still trying to understand this converter. So tell him if this flyback converter is power efficient than normal ones? If yes, how?
srihariraom
Joined Sep 27, 2021
14
The existing USB docking stations with power delivery does not use the flyback converter in it. I was just wondering if there are any advantages of using flyback converter instead of other buck-boost converters that are available in market(ex: MPS regulators). But, if they are likely less efficient then i think i can drop this idea.
