- Joined Jan 23, 2018
- 28,458
It does not match what I would expect from a switching regulator able to boost the input voltage. And none of the components in the PCB photo match a switcher regulator.I see this one has an output of 12volts +/- .3volts.
Dose this sound like a better unit ?
So it is not a device that can compensate for an input voltage drop. It is only a linear voltage regulator. It is not at all what the application requires. The input voltage range lower limit is 15 volts.
