Electromagnet waveform
ronv
Joined Nov 12, 2008
3,770
Thanks... also, the sim is taking forever to run in LTspice :eek:
Try skip initial operating point where you set the time.
The output would be to low with a 12 volt one. The transformer voltage is RMS so the peaks are stored in the cap (1.4X RMS), but with the 12vdc it's just 12 in 115 out.
cmartinez
Joined Jan 17, 2007
8,762
Alright, thanks, I think I found an exact equivalent for what you're specifying.
cmartinez
Joined Jan 17, 2007
8,762
The sim slows down to a crawl at exactly 8ms. I don't know LTspice that well to instruct it to skip stuff and go faster. Not familiar with directives.
ronv
Joined Nov 12, 2008
3,770
Try Edit, Spice analysis, then click check initial operating point Must have been a bad download.
cmartinez
Joined Jan 17, 2007
8,762
I'm reading 128 mA RMS at the transformer's output (L1), while I see 1.17 A RMS at (L2) and 947 mA RMS at (L3) that's a protection of approx 2 to 1 when compared to the specs of the transformer you're suggesting, right?
ronv
Joined Nov 12, 2008
3,770
Ooops, the 2 coils have different resistances. They should be the same. Probably doesn't matter much if it's 0.2 or 0.25, but lets make it 0.25 so we are both the same.
You probably could use a smaller one. I'm not sure if or how to derate for the square wave.
cmartinez
Joined Jan 17, 2007
8,762
Yeap... I noticed that too, but kept quiet 'cause I thought that's the way it was supposed to be... I've changed the values of both to 0.25 and it seems that the output is 124.5 VDC now. No big deal. Just out of curiosity, how could I fine tune the output in a simple way? just by changing the frequency of M1 and M2, for example? Or by applying PWM to both?
What I'll do is I'll buy the transformer that I mentioned and see how it works out. Then I'll trade it for a smaller one and see too if it can take the load.
I think this pretty much wraps up the power supply, thanks.
I'm about to buy the parts for both the supply and the driver. But I'll study the driver some more, make a complete parts list and get back to you before that happens.
Once again, thank you enormously for your help.
cmartinez
Joined Jan 17, 2007
8,762
Question, are the grounds on the left of the transformer (connected to M1 and M2) connected to the ground on the right?
I'm guessing the answer is NO
ronv
Joined Nov 12, 2008
3,770
Yes, everything is DC ground.
Will you generate the 60 Hz square wave with the micro? If so leave a small gap, maybe a usec between the opposing pulses so both FETs aren't on at the same time. It's also very important that they both be the same width so there is no DC in the coil.
The FET in the 120 volt line can be the same as the one in the driver. I'll see if I can find some logic level FETs for the 12 volts.
A fuse and a TVS might be a good idea.
cmartinez
Joined Jan 17, 2007
8,762
Well, the FET that you chose for the 120V side (M3) is pretty cheap, and it has a low Vgs(th) = 2.0V, that's logic level in my book . But it only has Drain to Source voltage of 100V. Which is no big deal in this power supply, since I'm reading 16V peak on startup and 14V on a normal run.
But the FET's at the left side of the transformer run at a different drain to source voltage (24V tops). Maybe we could use the same FET for M1 and M2?, only thing would probably be to switch them through transistors connected to the MCU, to make sure they're properly driven?
No problem with delay between switching of M1 and M2, I can easily make that happen with a $1.00 dlls 8051
ronv
Joined Nov 12, 2008
3,770
I keep screwing you up with the models. The FET I was talking about is the one in text for the driver.FDA33N25 I think.
Good idea if you level shift it with a transistor any old FET will work as long as it's rated for 30 volts or so and can handle the 30 amps at start up.
Yes, the same one for both.
Do you need a schematic for the driver?
cmartinez
Joined Jan 17, 2007
8,762
That would be nice, thanks... I'm willing to bet it's a simple totem-pole pair using a 3904 and 3906, for example? No need to sim them for me, just link me to a graph or something and I can take it from there.
EDIT, yes you're using FDA33N25 for the high voltage side of the driver, that's $2.66 dlls, not too shabby...
ronv
Joined Nov 12, 2008
3,770
Is your micro 5 volts?
