Electromagnet
Annie Vaws
Joined May 1, 2026
32
I have created an electromagnet, about 25mm long around a 12.5mm soft iron core. It has 12 full turns of 32 SWG copper enamelled wire. It is powered by 48V DC - for extemely quick (think eye blinking) pulses controlled by an on off switch.
However, the coil is getting incendiary hot very quickly.
Would switching to 26 or 24 AWG wire help?
(For background, this has to mimic a 1960s piece of tech).
TIA
Annie Vaws
Joined May 1, 2026
32
Yes that, or more turns.
If you calculate the power dissipated by the resistance of the wire for the applied voltage, you will easily see why it's overheating.
crikey, this is out of my league!
So, pardon my ignorance, (the dimensions are non-negotiable unfortunately) if I created 8-10 turns of 26 AWG - would that solve the issue do you think?
Sorry to be a dope!
ericgibbs
Joined Jan 29, 2010
21,575
Hi A,
If you have a variable power supply, I would suggest you start at say 12V and carry out a blink test, slowly increasing the voltage and determine the voltage required to actuate the solenoid driven device. We can then suggest ways of reducing the 48V, to suit.
E
Annie Vaws
Joined May 1, 2026
32
Hi A,
E
thanks Eric.
I don’t have a variable supply but will look into getting one.
Thank you
Annie Vaws
Joined May 1, 2026
32
What is the purpose of these? How are they being used?
They are to power a puppet lip sync mechanism - exactly as used in Gerry Anderson shows. The basic premise is you power the magnet for a split second, it attracts a steel plate, which pulls the bottom lip down via a pivot mechanism, power off and the attraction stops, allowing a spring to pull the lip back to closed position.
BobTPH
Joined Jun 5, 2013
11,656
Let’s do some math.
36ga copper wire is 1.36 Ohms per meter.
12 turns on a diameter of 12.5mm is 48 cm.
.48m x 1.36 is 0.65 Ohms
At 48V that is 74A and 3500W
That is more than twice the power of a typical space heater.
Likely, your power supply cannot provide that much power, which is why the coil did not nelt instantly.
Annie Vaws
Joined May 1, 2026
32
Let’s do some math.
So how would I solve this, given the dimensions I have? The coil itself cannot be larger diameter than 25mm - once wrapped around the 12.5mm core.
thanks
drjohsmith
Joined Dec 13, 2021
1,653
the power disipated is volts times amps,
you have too much heat, so you need to,lower either the volts or the current.
your volts is fixed, so you need to increaee resistance,
if you use thinner wire, the resistance is increased , and you can get mire turns on, meaning longer wire, thus also increasing resistance.
note more turns increases mabnetisum, lower current loweres magnatisum,
BobTPH
Joined Jun 5, 2013
11,656
Just read this. So you have 6.25mm for the coil. 36AWG wire is .127 mm, so you could get 49 layers of it, giving you 588 turns and needing only about 2% of the current you wound need with 12 turns.
3500/49 = 71W and 1.5A, which is a bit more reasonable.
Annie Vaws
Joined May 1, 2026
32
The core is 12.5mm diameter?
