DC Analysis Of This Circuit
28,527
If it is the circuit shown in post #1, I would start the analysis with out the feedback resistor "Rf" Also remove the input section and the output connections
The open loop DC analysis will be interesting if all of the forward diode and base-emitter voltages are assumed to be 0.7000 volts, because with no signal it would be a class B amplifier.
LvW
Joined Jun 13, 2013
2,045
My approach (assuming 0.7 volts across each pn-junction):
* Start with the DC value of Vout
* Base of Q2: V_B2=Vout+1.4 volts
* Base of Q4: V_B4=V_B2-2.1 volts (3 diode drops)
* Base of Q4: V_B4=Vout-0.7 volts
Now we have three equations for three unknown voltages (Vout, V_B2 and V_B4)
This should be enough for finding all other DC voltages and currents,
38,932
Because of negative feedback through Rf and the bias point depending upon the beta gain of the transistors, that is not an easy circuit to analyze, or a very good circuit in practice.
Note that the 10uF output coupling capacitor to the 8 ohm load, means the low frequency cutoff of the amp is about 2kHz.
dl324
Joined Mar 30, 2015
18,507
I'd take a simpler approach.
  1. Find the base current of Q1 by calculating the current through RB1 and the BE junctions of Q2, Q3, Q1, and RB2. \( I_{RB1} = \frac{V_{Sup} - 3*V_{BE}}{RB1+RF+RB2} = \frac{27.9V}{151.22kΩ}=0.18mA \)
  2. Q1 is now on and beta Q1 (I used 100 for simplicity) times the current calculated into the base of Q1 (18mA) is now flowing in RB1. Giving about 12V at the anode of D1.
  3. D1, D2, and D3 are now conducting, biasing Q2-5 on and you can calculate the voltage at the output (10.6V).
EDIT: corrected arithmetic error for output voltage, was 10.4V.
RRRRSSSS
Joined Jun 16, 2023
128
This circuit is used by many schools of engineering. Why would they use it if is a poor circuit?
RRRRSSSS
Joined Jun 16, 2023
128
Hi Dennis:
The sim is giving dc Vout = 12.25 V
dl324
Joined Mar 30, 2015
18,507
Hi Dennis:
I said it would take an iterative process to determine DC bias. I only gave 2 iterations.
If you want a "better" answer, you need to consult datasheets for diode and junction drops at the approximate current I gave and refine the currents and voltage drops. You should get a more converged answer after a couple more iterations.
But, the datasheets I have for 2N3904 and TIP31A don't give me enough information to refine the calculations...
