Piezo driver with +-20V using LTC7060 gate driver: 128kHz frequency
19Teju91
Joined Oct 8, 2024
Hello everyone,
I am currently working on a piezo driver designed for a 2.5nF load with a maximum current ranging between 50 to 100mA with a frequency of 128kHz. Since the load requires a sine wave for operation, I have created a simulation in LTspice using the LTC7060 IC.
However, I am facing difficulty increasing the dead time (dead band) between the turning off of the second MOSFET and the turning on of the first MOSFET. The design uses a full H-bridge configuration to achieve this. I would appreciate your guidance on how to increase this dead time.
Additionally, I am looking for solutions to generate sine waves with amplitudes of ±20V and ±50V (for two different piezo devices) while keeping the current within a maximum of 100mA.
I have attached the simulation files for your reference.
Thank you in advance for your support.
28,514
How about a "push-pull two device oscillator using a resonant circuit to set the frequency?? The immediate advantage is that it would be simple to have a sine wave. It would functionally need to be either a class "AB" or maybe a class "A" amplifier with a resonant load circuit. The technical name will be a "push-pull power oscillator", which is a very mature concept that goes back about a hundred years.
The unknowns for the project are the frequency stability and accuracy, and the available power to operate with.
ronsimpson
Joined Oct 7, 2019
4,857
That is 600A pk. in the MOSFETs. They will run hot. Only 160mA in C7.
You have too much current in L1, C2,3. Not much current in C7. This needs fixed.
Now L1 & C2,3 are the resonant filter. I think you should make L1 much bigger and reduce C2,3 until the caps almost disappear.
28,514
Unfotyunately I am not able to open the .asc file, that requires a simulator program that I do not have.
19Teju91
Joined Oct 8, 2024
Thank you for the response, added the details below,
Frequency stability : ±0.1%
Accuracy: ±10%Hz
Available power: 24V with 3-4A
19Teju91
Joined Oct 8, 2024
Thank you for the response, modified the design for the resonance and added the updated file
28,514
You will have less distortion with a resonant transformer inverter. I am not sure which will be the most efficient, but an optimized inverter can provide very low distortion.
So the question becomes an issue between max efficiency and minimum distortion.
fourtytwo
Joined May 16, 2022
20
hi 19,
In your redesign, the Gate 1 and Gate 2 periods are not the same, hence distorted output Sine.
E
I think this is caused by the delay parameter on V5 that should be exactly half the period.
Secondly I think you could turn of your mosfets faster with a schottky (eg bat54) across R4,5,11&12 anodes to gate.
According to the spec 500K deadtime resistors are the same as none and will result in just 75nS so you have to get your mosfets off that fast! Or use a different drive chip or mosfet.
Why are your PWM inputs not exactly 50% duty cycle ? with that chip you cannot influence DT externally via the PWM input but maybe you have another reason.
