Convert triangle wave to sine wave.
MrsssSu
Joined Sep 28, 2021
267
Hi readers, the IN node has triangular wave converted from square wave pulse. This Op-Amp acts as integrator. However, when I attach the same integrator circuit to convert this triangular wave (IN) to sine wave, the Output (OUT) I got is still quite triangular and not quite a good sine wave.
Question: How to I get sine wave at OUT ? I have attach my LT spice file below. Thank you for reading :)
Audioguru again
Joined Oct 21, 2019
6,826
I filled-in the TRAN command (100ms, 98ms and 10ms) to see the waveforms.
R6 was missing and its 100 value was way too low, I made it 16k.
I added 2nF integration capacitors parallel with R2 and R5 then the simple 2nd-order filter removed most of the harmonics, but it reduced the level.
