Convert AC Induction Motor To BLDC(or PMDC///PMSM) ..#2
luka.lakirati
Joined Mar 8, 2026
Also i think their Magnet to Pole(teeth) ratio are different.
I will make my first E-car using 3Phase Induction electromotor(like tesla model s)(not soon)
Hey!! I’m a little bit late haha, but I’m also interested in the idea of converting a three-phase AC motor to BLDC. I just want to ask: did you finish your project? Does the motor work? Does it fulfill your expectations? How efficient is it, and was it worth doing?
Mod: link to old thread,
https://forum.allaboutcircuits.com/...otor-to-bldc-or-pmdc-pmsm.159685/post-1397251
28,531
IT should be possible to use a circuit of a three pahse output variable speed drive to produce a similar function to a BLDC motor and driver circuit. Certainly they are not at all the same. BUT many VS drives first rectify the mains power to DC, soit should be possible. NOTEthat I did not say it would be simple or easy.
vandveuser16776
Joined Feb 21, 2026
232
BLDC = Brushless DC motor. These motors have magnets spinning around a fixed stator, almost always inside a cylindrical rotor, otherwise , the centerfuge force will send magnets flaying.
Ian0
Joined Aug 7, 2020
13,311
There's no such thing as a brushless DC motor. All DC motors have brushes. What the world likes to call a "brushless" DC motor is in fact an AC permanent magnet synchronous motor, driven by an inverter.
So do you want to convert the induction motor that you have to permanent magnet? That might be tricky, but you can run a 3-phase induction motor off an inverter, and it isn't quite so tricky as running a synchronous motor as you don't need to time the signals to match the position of the rotor.
28,531
IF you include the driver as a part of the motor, THEN you can certainly have a "brushless package."AND THAT is what gets called a BLDCmotor. Many of them, maybe even most of them, also include rotor position sensors so that they always start out the same. So if you include the "package" that it must have to run, then there is such a beast as a brushless DCmotor. That may confuse some folks, no doubt.
MaxHeadRoom
Joined Jul 18, 2013
30,881
I don't neccesari;ly agree there, the BLDC typically uses DC switching to one pair of the three windings at a time, the applied signals do not alternat or reverse polarity.Hence DC.
The identical motor can also be driven with 3 phase sinusoidal. making this version basically AC.
Just takes a simple googling
Brushless DC electric motor - Wikipedia
Ian0
Joined Aug 7, 2020
13,311
That's an interesting thought, though I will add one a couple of things:
Driving the motor with unipolar signals isn't an efficient use of the windings so it will probably only be done for low power motors.
If you drive on terminal with a unipolar signal, then the effect of the motor being a generator will put a voltage of the opposite polarity on that terminal when it is not driven, so a measurement of the voltage between the terminals would still give AC.
Very much the case of "depends how you look at it".
28,531
What I see here is an argument about exact definitions. This argument will produce nothing of value at all.
Therefore I suggest abandoning it and thus saving a bit of bandwidth.
Ian0
Joined Aug 7, 2020
13,311
That would be room twelve. !
Is it the 5 minute argument or the full half hour?
What I'd like to know from the TS, is whether he simply wants to make his motor rotate using a DC supply bu adding some electronics, or whether he wants to convert it to be a permanent magnet motor.
An AC supply alternates in sinusoidal pattern, which is not used in a single BLDC on this earth.
" The usual waveform of alternating current in most electric power circuits is a sine wave, whose positive half-period corresponds with positive direction of the current and vice versa (the full period is called a cycle). "Alternating current" most commonly refers to power distribution, but a wide range of other applications are technically alternating current although it is less common to describe them by that term. " Wikipedia
28,531
All that it takes to convert a three phase inducion motor into a brushless DC motor is a variable speed drive system that runs from a DC source. BUT usually these packages are separate, so it does not work out quite right. AND, most VS drive systems use an AC feed.
