Convert Modern ECU 5v Pulse Output to the Original 12v RPM Tachometer
HadyShaltout
Joined Oct 14, 2024
30
Hi There!
I tried to make a DIY circuit to convert the modern ECU 5v pulse of RPM for my VW GOLF-2 which upgraded to GOLF-4 engine to the original 12v analog tachometer with the most known circuit of a relay coil, resistor and couple of diodes but it failed after 2000 RPM, it drops to zero when reach 2000.
I asked the new genius GPT and he gives me a pretty complicated circuit in code which is very hard to read, so I draw it on a paper as as I can understand it and need to ask pros. before applying it on my car.
sghioto
Joined Dec 31, 2017
8,765
Really surprised using a relay it worked to 20K! Did you mean maybe 2K rpm?
That circuit won't work as drawn using a N channel mosfet.
Here's one of several ways to level shift the 5 volt pulse to 12 volts.
sghioto
Joined Dec 31, 2017
8,765
Has the TS verified that the tach will not work with the 5 volt signal??
Not sure. I'm still trying to figure out how in the world he was getting 20K rpm out of that engine. :eek:
I would also like to see that relay circuit that fails at 20K rpm mentioned in post #1.
28,636
The old SUN tachometers did use a quite unusual relay to deliver a charge from a cap to move the pointer. It worked quite well until things wore out or the battery got weak.
AND, triggering off of the ignition pulses instead of one plug would be 4x the speed, maybe. OR maybe contact bounce multiplied the pulses per firing.
But an amplifier with a gain of 2.5 is not that hard. On transistor should do it, but the load resistor selection will be a challenge.
HadyShaltout
Joined Oct 14, 2024
30
Yes, The VW Golf-2 analog tach works with 12v only, and I mean 2K rpm, sorry for that. The tachometer drops when reach 2000 rpm, and it's not stable when accelerate but it's stable without accelerating on 9-10K rpm.
I didn't use a relay, I used the relay's coil only, I think it's equivalent to a resistor of 10K, I'm not sure about the value.
HadyShaltout
Joined Oct 14, 2024
30
@sghioto @ronsimpson
Hey guys,
Here's the circuit but unfortunately it doesn't work,
Here's a video for the first test, I have tested the input and output with a tester pen works with 5 volts, the input of ECU out (5v) make the tester flickering while the output is always 12v with no filker and it makes the tester always ON, so the RPM always zero.
I noticed that after the 100K resistor, there's no volts on the multimeter and the tester pen didn't work, I think the output voltage after the resistor is very small.
anyway, the circuit is working without any short or blown fuse but the output is always 12v.
I draw the circuit in the Crocodile Technology and it works perfectly.
So What's wrong?
Thanks for your help
sghioto
Joined Dec 31, 2017
8,765
If the pulse is 5 volts it should never read above 5 volts and that will depend on the duty cycle.
If the duty cycle is 50% the voltage should read appx 2.5 volts
The meter is measuring the average voltage as the signal goes from low to high.
The 6 to 8 volts is telling me the signal is not a 5 volt pulse.
Really need to see the pulse on a scope.
Is the ground connection on the circuit board the same as the ECU ground ?
