Controlling the supply to a Hall effect Sensor (A3144E) with another A3144E
sghioto
Joined Dec 31, 2017
8,735
I think it's all OK but explain again the purpose of the three1N5408 diodes, the 1N5404 and the 1F/90 volt cap.
Is this circuit working as shown on the schematic?
sghioto
Joined Dec 31, 2017
8,735
Here's my only suggestion for some isolation on the latch circuit. Add C3 and re-route power to the 80 volt boost module.
Is that really a 1 Farad 90 volt cap?
sghioto
Joined Dec 31, 2017
8,735
After some more thought and if the timing is proper you may be able to parallel H1 and H4 as the trip and H2 and H5 as the reset.
H6 would get power from Q2 as does H3 but the output of H6 would require a separate latch and mosfet to drive the solenoid.
