Hey everyone, here are two questions I got during a interview and I need some help better understanding them.
1. The first problem has two parts and I attempted the first part. I tried to follow the convention current flow from the two sources and found the current flowing through the two resistors but I'm not sure if I got the directions right.. What I wrote in red does not follow KCL and I'm not sure what to do. In the second part, a 20 ohm resistor is added to the circuit and in red I marked what I think the current flow through the circuit is but other than that I'm not sure where to start..
2. In the second question I was told that one of the ammeters in the circuit is not giving the right reading and I had to analyze the circuit and figure out which one it is. I said that if I know all the resistor values I could calculate the current going through each resistor because since they are all in parallel I know the voltages at each node are the source voltage but I was told that the resistor values are unknown and I should only work with the ammeters and then suggested that I take off R4 and try again.
Thanks for any help you can offer!
