Hi,Yes they are interesting in their differences from mine. My power values are negative so is that because either the current or voltage is negative? You seem to be using my circuit so why is the supply power plot the inverse of mine, but the capacitor one is fairly similar? Hmmmmm
Well if that's the case, then you may be seeing the real values which means you can either try to improve it or just uses it as is.The sim efficiency is quite close to that measured and the original circuit layout I gave is the basis of the whole circuit, so there aren't other parts that are being ignored. I agree that over 100s the value may be different than over 1s, just as I have shown in post 138 a difference with different PRFs. But so long as I am consistent in the measurement time, bench and sim, then they have value for my purposes.
The sim efficiency at 100Hz is much higher than the bench value, whereas at 50Hz they are closer. The sim data will need to be used selectively.Well if that's the case, then you may be seeing the real values which means you can either try to improve it or just uses it as is.
__
