Bilge pump circuit for model sailboat
And that is only driving the LED2 circuit.
3.8 volts indicates the resistance of the probe in the water is appx 31.5K ohms.
That's close to what I read using tap water with an ohmmeter.
Are the probes nice and clean?
Maybe connect terminal #1 of both probes to the 7.2 volt battery source.
Ken_NJ
Joined Feb 22, 2021
122
That was it, dirty probes. I gave all four ends of the wires a fresh coat of solder and it works fine.
As part of maintenance will have to touch the ends up once in while.
In the meantime I'm figuring how to get the schematic right so I can arrange a PCB.
Ken_NJ
Joined Feb 22, 2021
122
Thanks. Here is mine. I still have R7 & R8 in place. I added 2 pin connections where the battery connects, where SW1/2 connect and for the probes. It should bring over pads for those points to the PCB I think. Pretty sure I have footprints in place, might have to change them for C1/2. For some reason the ERC said PWR-Flags were needed.
I ran the ERC and there are no errors.
This seem OK to you?
