Bilge pump circuit for model sailboat
sghioto
Joined Dec 31, 2017
8,750
And that is only driving the LED2 circuit.
3.8 volts indicates the resistance of the probe in the water is appx 31.5K ohms.
That's close to what I read using tap water with an ohmmeter.
Are the probes nice and clean?
Maybe connect terminal #1 of both probes to the 7.2 volt battery source.
Ken_NJ
Joined Feb 22, 2021
137
That was it, dirty probes. I gave all four ends of the wires a fresh coat of solder and it works fine.
As part of maintenance will have to touch the ends up once in while.
In the meantime I'm figuring how to get the schematic right so I can arrange a PCB.
Ken_NJ
Joined Feb 22, 2021
137
Thanks. Here is mine. I still have R7 & R8 in place. I added 2 pin connections where the battery connects, where SW1/2 connect and for the probes. It should bring over pads for those points to the PCB I think. Pretty sure I have footprints in place, might have to change them for C1/2. For some reason the ERC said PWR-Flags were needed.
I ran the ERC and there are no errors.
This seem OK to you?
Ken_NJ
Joined Feb 22, 2021
137
The motor is rated for 6v. Can I replace U1 with a 7806 (which I have on hand). Would the circuit need to be changed at all by using a 7806?
sghioto
Joined Dec 31, 2017
8,750
6 volts is fine but the regulator may not function properly with a supply of 8 volts as the dropout voltage is typically 2 volts.
A lower dropout regulator is recommended.
Ken_NJ
Joined Feb 22, 2021
137
The min input voltage for U1 is 6.5v. Specs Before designing this I was going to use a 6 cell NiMH pack. Even that may cut it close should the 6 cell pack get low. I can go to an 8 cell pack or maybe save some weight with a small 3s Lipo pack.
I can also keep the pads for the current U1 and add the pads for a 7806, they would be in parallel so I can decide anytime which one to use.
Thoughts on this?
Ken_NJ
Joined Feb 22, 2021
137
Tomorrow I'll test with the 7806/heat sink and another idea I have.
In the meantime I modified the schematic with the 7806 and connectors to make up the PCB.
It'll have traces on both sides. What a time consuming thing this was.
Ken_NJ
Joined Feb 22, 2021
137
Did some cleanup and minor changes. Going to extend the board end by R7/8 so the pump can be mounted to the board.
Found the following...
7806/heatsink - 5.4v at the pump, circuit draws 295ma
RBT10W - 4.86v at the pump, circuit draw 186ma
There was no significant, very slight, change in the water flow from the pump. So I'll stick with the RBT10W but I'll leave the 7806 position in the PCB.
Ken_NJ
Joined Feb 22, 2021
137
Any KICAD experts? I'm a bit confused. I think I found the answer online.
The F.CU layer is the Front/Top copper layer (RED). And the F.CU layer is the side the components go on. I think I have my traces on the wrong side. The red traces, which are the majority of traces, should be on the B.CU layer. And any of the blue traces I have should be on the Front/Top layer. I know it can go either way, but I think I need to flip the traces, right?
And I cannot seem to get the TL2285EE (SW1) switch to appear in the 3d view. That is not so important but I'd like to have this complete.
