Simulating Howland current pump in Multisim - something amiss
0ri0n
Joined Jan 7, 2025
197
The colour of U1 suggests the model was included by you and is not from the Multisim main database. Probably something wrong with the model. Try an appropriate difference amplifier from the main database (e.g. AD629 or similar) or build a discrete one yourself with a +/-18V op amp.
I used an INA117 in the attached example. Output current tops out around +/- 9 mA because the output of the INA117 has to supply quite some current and is simply limited by how close it can get to the supply voltage rails.
38,946
The data sheet says it should be able to output +20mA when the supply voltage is 5V above the output voltage.
(Below from data sheet with a ±15V supply.
Your sim show a difference of only 3.5V between the plus supply and the output voltage which is thus what's likely limiting the current.
Increasing the value of the 10kΩ resistors would increase that voltage difference and thus the maximum output current, but that also would increase the supply voltages to U1.
Alternately reducing the 10kΩ resistor values to about 6.5k and adding 5V Zeners in series with each resistor would keep the difference from ever dropping below 5V without affecting the supply voltage across U1.
MaximumGain
Joined Sep 12, 2026
Thanks to 0ri0n - yes the model is one I imported, your suggestion will allow me to move forwards.
Thanks to crutschow for peeling the next layer of the onion for me.
I'm grateful to both and am now going to the shed to mutter about simulators for a while...
38,946
Below is the LTspice sim of the basic circuit with a 15V Zener addition (D1 and D2) to keep the supply voltage at least 5V above the output voltage so that doesn't limit the current:
(I had to substitute with similar part models I had for U1, U2, Q1, and Q2, but that should not have a significant effect on the circuit simulation).
The output current (green trace) can now go above 10mA, shown going from 0 to 12ma for a 0-12V input (yellow trace).
