The schematic hasn't changed from post #46.
It just needs power and ground to U1 (which is on the layout) along with the decoupling capacitors (the only moderately critical location is for the 0.1μF directly across pins 4 and 11 of U1).
The erratic behavior with LEDs can be related to their non-linear resistance with voltage.
A small (say 5-10W) incandescent in parallel with the LED may solve the problem with pulsing.
This bulb can be located anywhere, such as next to the circuit, whereas the LED can be on the tower.
