Patch antenna phased array
Tryui
Joined Sep 20, 2021
208
Good morning, I'm planning to build a planar phased array, the purpose of which is to perform near-field focusing (beamforming) in the non-radiating near-field (Fresnel zone), therefore in an area in front of the array. I decided to use a carrier frequency of 800 MHz, and use cavity patch antennas, and divide the antennas into two groups, the first group having a carrier frequency of 800 MHz and amplitude modulated (pulses) at 200 Hz, and the second group also having a carrier frequency of 800 MHz, and amplitude modulated at 300 Hz, to create a difference beat in the target area. My problem concerns the size of the patches, I'm undecided between half-wave or quarter-wave, the half-wave patches have greater gain and less beam distortion, but are large, while the quarter-wave patches have greater asymmetry, less gain but are smaller, so for my project which of the two options is best???
Danko
Joined Nov 22, 2017
2,250
@MisterBill2 @Danko @BobTPH @Pyrex please can you help me with this thread, is very important for me
Journal of Communications, vol. 19, no. 4, 2024
"Design of Microstrip Patch H-Notch Antenna for Vehicle Using Array Systems"
Raed S. M. Daraghma
"Design and Analysis of Microstrip Patch Antenna Arrays"
Ahmed Fatthi Alsager
https://www.diva-portal.org/smash/get/diva2:1312395/FULLTEXT01.pdf
"Microstrip Antenna Design Handbook"
Ramesh Garg, Prakash Bhartia, Inder Bahl, Apisak Ittipiboon.
https://uodiyala.edu.iq/uploads/PDF ELIBRARY UODIYALA/EL37/Microstrip Antenna Design Handbook.pdf
Tryui
Joined Sep 20, 2021
208
Raed S. M. Daraghma
View attachment 369942 View attachment 369943
wow danko your links have many pages, I'm reading them but it will take me a couple of days to study well
Tryui
Joined Sep 20, 2021
208
That antenna is a critical aspect of the project. Don't compromise make or break aspects unless it's absolutely necessary.
If size is make or break, like in a small cell phone, a PIFA might be one choice. If size is just a want, what will a PIFA compromise on the total design.
https://www.antenna-theory.com/antennas/patches/antenna.php
https://www.antenna-theory.com/antennas/patches/pifa.php
Excellent, I had already read the links you recommended, and yes, they talked about the fact that the presence of the pin connected to ground on the edges of the pipe increases the asymmetry, but since in near field focusing, having phase precision and symmetry is of vital importance, then I think the half-wave patch is the best choice.
Tryui
Joined Sep 20, 2021
208
@Danko @nsaspook @MisterBill2 @BobTPH @Pyrex ok, if I wanted to implement the multiarray structure, especially volumetric arrays with which all the antennas of all the arrays are powered, to be able to tighten the focus also on the Z axis, is it better to use an egg-shaped volumetric array with vivaldi antennas, or a dome structure with half-wave patch antennas??
Danko
Joined Nov 22, 2017
2,250
AI:
"For superior field focusing along the Z-axis (along the main axis of propagation to create a 3D focus in the near-field),
the egg-shaped volumetric array with Vivaldi antennas is unequivocally better.
A dome structure with patch antennas cannot achieve tight Z-axis focusing due to its geometric constraints and element types."
Tryui
Joined Sep 20, 2021
208
AI:
Thanks Danko for your reply, you are always very kind, yes, the Vivaldi offer a wide bandwidth, useful for correcting any construction problems and they do not have the rear ground plane, but they have the problem of being very bulky in depth, that's why I was thinking of the dome with half-wave patch with cavity, and arranged as staggered concentric rings, usually the parabolics/domes are excellent for the focus, I don't know, I'm very confused, I also did the same search with Google Gemini, and it reiterated that the dome with patch is the best choice, at this point I'm even more confused
