Broken U.FL / IPEX antenna cable connector on Meta Quest 2 controller – repair options?
john4953453
Joined Mar 25, 2026
I’m repairing a Meta Quest 2 left controller and damaged a small antenna cable.
The board-side connector is still intact, but the cable-side plug (the tiny snap-on head) broke off the coax cable. From what I can tell, it looks like a U.FL / IPEX micro RF connector.
I have:
  • The motherboard connector still attached and undamaged
  • The cable with the connector head missing/broken
Questions:
  1. Is it possible to reattach or replace just the connector on the cable?
  2. Would replacing the entire coax cable/antenna be the correct approach?
  3. Is direct micro-soldering (center conductor + shield) a viable workaround, or will it cause signal issues?
I’ve attached close-up photos of:
  • The board connector
  • The damaged cable
Any advice on the best repair method would be appreciated.
