Why don't you just put a discrete CMOS inverter on the output? If the signal inversion bothers you, you can use a small inverter to drive a big one.1. I want rail to rail.
2. The transistor configuration is inverting. A hysteretic oscillator requires an inverting Schmitt trigger to work. two inverting gates is a buffer.
3. A CMOS 555 at low voltage has a very low drive, I wasn't sure it could handle 1ma at 5V Vcc.The transistors will raise that considerably.
Once upon a time everything in your parts collection was a specialty part. As my grandaughter (bless her heart) would say: "OK boomer".Like many of my brain fa..s projects, this is much a learning exercise as anything. I am very against buying specialty chips for this kind of project.
If you use 2 CMOS inverters, a small one driven by the timer, and a big one driven by the first inverter, the amount of current you can get will be limited by the power supply. Voltage swing should be essentially rail-to-rail if you choose appropriate MOSFETs.I just want to know what the maximum current for the minimum voltage drop I can get from something like this.
Hi Wendy, how can i contact you? There's no button for conversation in your profile.At this point I am not worried about parts count, that will come after. I just want to know what the maximum current for the minimum voltage drop I can get from something like this.
Aen't D1 and D2 the wrong way round in this circuit?So I tried this design next:
and as expected the duty cycle was just about unusable. Fortunately there is away with 555 to control the duty cycles.
View attachment 270218 View attachment 270219
555 Out transistors output
Now to relay and try out this schematic:
you know what assumptions get you don't you? Think the parts list projectThe unmarked transistors are also backwards if they are European BCxxx type.
