Electronics Experimenter's Parts List 2.0
Status
Not open for further replies.
35,327
Copied from Components Selection Guide in Datasheets, Manuals & Parts Identification forum.
#19 - Experimenter's Parts List
Note from @Wendy: As an active experimenter and Moderator I plan on being very active on this list. Any changes I make will be marked with an asterisk*, @MrChips started this project, and it is a really good idea so I'm going to run with it.
Started: 2012.12.30
Revised: 2021.04.16 Added Darlington Transistors
Here is a suggested list of components that any electronics hobbyist or experimenter may want to keep at hand.
Quantities shown in ( ) at your discretion. Any part with the label (download) will download the .pdf datasheet if clicked.
Resistors
Here are the standard E12 values: 10 12 15 18 22 27 33 39 47 56 68 82
From this list I have selected the most common values:
(10) 100Ω 1/4W
(10) 220Ω 1/4W
(10) 330Ω 1/4W
(10) 470Ω 1/4W
(10) 1kΩ 1/4W
(10) 2.2kΩ 1/4W
(10) 3.3kΩ 1/4W
(10) 4.7kΩ 1/4W
(10) 10kΩ 1/4W
(10) 22kΩ 1/4W
(10) 47kΩ 1/4W
(10) 100kΩ 1/4W
(10) 220kΩ 1/4W
(10) 470kΩ 1/4W
(5) 1MΩ 1/4W
(5) 10MΩ 1/4W
(5) 22MΩ 1/4W
Capacitors
( 5 ) 1nF
(10) 10nf
(10) 100nF ceramic
(10) 10μF 16V electrolytic
( 5 ) 100μF 16V electrolytic
( 5 ) 470μF 16V electrolytic
( 5 ) 1000μF 16V electrolytic
Diodes
( 5 )1N34A germanium diode (pdf)*
(10)1n914 signal diode (datasheet)*
( 10)1N4158 (download)*
( 10 )1N4007 (download)*
(10 )1N5817 Schottky diode (download)*
( 1 ) 006B Integrated Diode Bridge (download)*
Transistors
( 20 )2N2222A NPN Switching Transistor (download)*
( 10 )2N3904 NPN Transistor (download)*
( 5 )2N3906 PNP Transistor (download)*
( 2 )TIP100 NPN Darlinton Transistor
(2 )TIP105 PNP Darlington Transistor
MJE3055 NPN Power Transistor
MJE2955 PNP Power Transistor
Integrated Circuits
( 2 ) LMC555 Timer
( 2) LM7805 (download)
( 2 ) LM324 Quad single supply opamp
( 2 ) LM339 Quad single supply comparator (download)
( 2 ) LM358 Dual single supply opamp
( 2 ) LM386 Audio loud speaker amplifier (download)
Opto Electronics
(10) Red LED
( 2 ) Light dependent resistor (LDR)
Hardware
8-pin DIP socket
14-pin DIP socket
16-pin DIP socket
20-pin DIP socket
Tactile Switches (for Protoboard Circuits)*
solderless breadboard
22-gauge hookup wire
24-gauge hookup wire*
single row 0.1" pitch pin headers
dual row 0.1" pitch pin headers
Miscellaneous
32768Hz quartz crystal
8MHz quartz crystal
2-cell AAA battery holder
2-cell AA battery holder
4-cell AAA battery holder
4-cell AA battery holder
9V battery clip
8Ω speaker
piezo buzzer
Status
