555 voltage booster
Wendy
Joined Mar 24, 2008
23,810
So anyhow I gave up my old design to work I just cannot get enough drive from the CMOS 555 to drive the transistors very much. So I went to this design:
and of course R4 and R5 are too big of a load for Q1 and Q2 I will show the oscope results in a bit.
dl324
Joined Mar 30, 2015
18,453
1. I want rail to rail.
2. The transistor configuration is inverting. A hysteretic oscillator requires an inverting Schmitt trigger to work. two inverting gates is a buffer.
3. A CMOS 555 at low voltage has a very low drive, I wasn't sure it could handle 1ma at 5V Vcc.The transistors will raise that considerably.
Why don't you just put a discrete CMOS inverter on the output? If the signal inversion bothers you, you can use a small inverter to drive a big one.
That idea was used 4 decades ago to get rail to rail output from opamps like LM358.
Wendy
Joined Mar 24, 2008
23,810
Sometimes I get so fixed on a design goal that I lose sight of the ultimate goal. Being fixated on a CMOS 555 was probably not the best decision, I will work through this design. Then maybe start from scratch. If I can I want to keep the symmetrical square wave.
Ian0
Joined Aug 7, 2020
13,248
I'd still recommend a low-side driver such as a MCP1402 as the output driver. Big reduction in component count.
Wendy
Joined Mar 24, 2008
23,810
Like many of my brain fa..s projects, this is much a learning exercise as anything. I am very against buying specialty chips for this kind of project.
Ian0
Joined Aug 7, 2020
13,248
As most gate drivers have hysteresis on the front end, they will oscillate like a 555, so you could eliminate the 555 from your circuit.
22,111
Once upon a time everything in your parts collection was a specialty part. As my grandaughter (bless her heart) would say: "OK boomer".
Wendy
Joined Mar 24, 2008
23,810
At this point I am not worried about parts count, that will come after. I just want to know what the maximum current for the minimum voltage drop I can get from something like this.
dl324
Joined Mar 30, 2015
18,453
If you use 2 CMOS inverters, a small one driven by the timer, and a big one driven by the first inverter, the amount of current you can get will be limited by the power supply. Voltage swing should be essentially rail-to-rail if you choose appropriate MOSFETs.
Rosevet
Joined Jun 20, 2022
6
Hi Wendy, how can i contact you? There's no button for conversation in your profile.
dl324
Joined Mar 30, 2015
18,453
You need 10 posts before you can initiate private messages. Then you'll be able to start a conversation with a member by hovering over the member's name under their avatar:
Wendy
Joined Mar 24, 2008
23,810
So I tried this design next:
and as expected the duty cycle was just about unusable. Fortunately there is away with 555 to control the duty cycles.
555 Out transistors output
Now to relay and try out this schematic:
Audioguru again
Joined Oct 21, 2019
6,826
For this circuit, the transistor and full IC part numbers should be on the schematic, not on another thread that was 1.6 years ago.
Many of us use American, European and Oriental transistors and their three pinouts.
