555 voltage booster
dl324
Joined Mar 30, 2015
18,524
Of course I am always open to suggestions.
For currents of less than 3-4A, I'd use AO3400 and AO3401. I've tested the ones I have to 1A.
I bought mine on AliExpress for a couple cents each. I was willing to take a chance because the price from other, more reputable places, were too expensive. They're SMT and SIP adapters are about a dime each.
Wendy
Joined Mar 24, 2008
23,869
I only have one hand to solder with components I will only use through hole components for these kind of experiments. I tried logic level MOSFETs with a CMOS 555 that is posted earlier(much earlier) and was not happy with the results so now I am using a stock 555 to run these experiments due to the built in current drive. A cmos 555 cannot drive any transistor circuit at 5 volts power supply. Through hole logic level MOSFETs are plentiful and cheap.
Note I'm not giving up on protoboards. Before the stroke I was making printed circuit boards left and right. I do what I can and ask for help when I can't.
DickCappels
Joined Aug 21, 2008
10,661
Another approach now that the chips are almost dirt cheap.
Still an NE555 is a good way to get there is you want to wire it up yourself (I have plenty of them now that they too are almost dirt cheap)
Wendy
Joined Mar 24, 2008
23,869
In general I am looking to protoboard something on a protoboard, which by definition means through hole components.I have already created a usable 9 Volt battery equivalent from 5 volts. If I can get more by using larger capacitors then I will not put that in my mental toolbox for future designs I am thinking in terms of 5 Volt wall warts as quick and dirty power supplies . There are many applications where 5 volts by itself is not enough . And I would love to be able to power an op amp circuit with +/- 10 volts. I am going to retry this experiment with multiple voltages month and much larger caps. Just another tool in my mental toolbox. I picked 20 kHz because it is out of human hearing range which means this power supply can be used for audio projects.
