2SC4488 NPN Transistor for SPICE
alexrecai
Joined Apr 8, 2022
Hi there!
I am currently looking for 2SA1708 and 2SC4488 transistor models to integrate into Spice, but I could not find any model on the web. Could you please help me if you have the related models? Or can you please give me feedback about what parameters are the most important ones to model these transistors correctly?
I really appreciate any help you can provide. Thanks...
Audioguru again
Joined Oct 21, 2019
6,826
The model for a transistor usually uses only "typical" specs. Then a transistor with minimum or maximum specs might not work when the circuit is built.
Many simulated transistors work perfectly even when the circuit has them severely overloaded.
38,953
If the application requirements are not critical, than you can use a model of a transistor with close to the characteristics of the one you want to use.
As AG noted, just make sure to design the circuit so that it can operate with the transistors at their maximum (worst-case) limits, not just nominal.
Alec_t
Joined Sep 17, 2013
15,171
As AG says, Spice models are usually based on 'typical' specs (as per the transistor datasheet). Due to manufacturing tolerances there can be wide parameter value variations from transistor to transistor, of the same type, so any simulation can only be an approximation of reality. Exactly what do you mean by "correctly" in this context?
Audioguru again
Joined Oct 21, 2019
6,826
The simulator does not design the circuit, you do it.
You must design the transistor circuit with enough DC negative feedback to cancel the wide range of DC hFE that a transistor has in its datasheet. Opamp input current and input offset voltage ranges are also important specs for designing a circuit that the simulation models do not have.
alexrecai
Joined Apr 8, 2022
Thank you very much for your kind and helpful answers. I have found a similar transistor in spice and I will use that in my circuit.
Thanks again.
sparky 1
Joined Nov 3, 2018
1,218
The data sheet NPN high voltage, high speed switching. Ft 120MHz, 1W
You need to know which category R S T for hFE or use a tester if available
