Wired communication between two fpga
mazraedar
Joined Nov 25, 2021
Hello everyone,
First post here, I'll try to detail my issue as much as possible.
So I have two FPGAs, each of them on a different card. Some pinouts communicate via a cable (with a total of 50 pins). The cable is pretty short ( 20 centimeters) and is fully Shielded.
The problem beggins when I try to use a longer cable. The new cable is 1.5 meters long and is separated in 3 parts with two high density connectors. When I measured the overall resistance, it was only 0.6 ohm (where the short cable was 0.4 ohm). So I don't think it is due to a power issues.
Also, I thought about Impedance matching, since I use some alternative signals, but this means I'll have to remodel the PCB.
So I was wondering if there are any options in the VHDL code that is meant to be used for long cable communication.
I'm sorry if it's a bit messy I tried to make it as clear as possible.
Thank in advance
drjohsmith
Joined Dec 13, 2021
1,658
What problem do you have ?
I'm guessing that its signal integrity on the longer cable,
I'm guessing its ribbon cable you have.
In that case, To answer my own question...
You are suffering over / undershoot,
Caused by the conductors being close to each other, and the speed of the rising / falling edge.
The answer, might be to slow the edge speeds down,
some , may be all FPGAs now,
have options to select slow / fast edge drivers,
and / or
option to change drive strength,
each or both of which will affect the edge speed.
