Prewired 5mm LEDs w/ no resistor??
johnaustinkaty
Joined Jul 16, 2021
284
I was wondering if anyone supplies prewired 5mm LEDs that don't have the resistor preinstalled? I'm using two LEDs in series so I will be using a 470 ohm resistor on my PCB. Any supplier suggestions?
Thx all
panic mode
Joined Oct 10, 2011
5,458
as far as i know they always do include series resistor. that is the point if getting assembly. did you consider connecting them in parallel?
johnaustinkaty
Joined Jul 16, 2021
284
Yes. I had been bypassing my resistor and connecting in parallel, but during my PCB development recently, someone had stated they should be in series, which I agree with. Also, using a 470 ohm resistor in series provides the brightness I am looking for. I think they are prewired with 680 ohm ???
johnaustinkaty
Joined Jul 16, 2021
284
OMG! I will continue with manually removing the provided resistors as I have done to ten pairs already. The ones you posted above are crazy expensive:
Thx for the info.
John
35,299
Thx all
What?
LEDs usually come with no series resistor. Maybe I don't understand the query.
B-JoJo-S
Joined Jan 3, 2026
604
What voltage do you want to use?
How bright do you want them (10mA, 15mA) ?
What's their forward voltage?
The ones you already have - what voltage were they intended to be used on?
johnaustinkaty
Joined Jul 16, 2021
284
Maybe it would be best to use two non prewired LEDs and solder the three required wires on... six solder joints:
12v (on PCB) to anode
cathode to anode
cathode to pad on PCB (to 470 ohm resistor, to GND)
