Driving Leds with ac
bertus
Joined Apr 5, 2008
23,014
There are no leds that run on 120 Volts AC.
There are led lightbulbs available that run on 120 Volts AC, those have a circuit inside to accomodate the led.
Standard leds can not stand more than 5 Volts reversed voltage.
Bertus
Futurist
Joined Apr 8, 2025
950
Looking for a way to have a general purpose red led to run on 120vac, and another to drive 24vac for a blue led
Step the AC down using a small (as in low power rating) transformer, this will 1) isolate your circuit from the AC supply and 2) greatly reduce the voltage(s) you are dealing with.
Don't screw around with circuits that connect to the unisolated AC supply, there's no need and it can be fatal.
38,881
a series 390nf cap rated 200 volts or more and a 1N4007 diode wired in reverse polarity across the LED should suffice.
The diode could be a 1N4148 since the reverse voltage is just the LED forward drop.
Alternately you could use four 1N4148s in a bridge circuit, or other small bridge module, to allow the LED to conduct on both half-cycles, reducing the chance of noticeable flicker.
ronsimpson
Joined Oct 7, 2019
4,845
I had problems with my furnace. It runs on 120Vac and 24Vac. I added many lights just like those. From the front panel I can see if the 120 and 24 are OK. If the gas is on, of the fan is on, if the pump is on. I can see if the igniter is on. I no longer need to get the meter out and measure all the test points.
Ramussons
Joined May 3, 2013
1,572
Or simply connect another LED across the first, but reversed.
B-JoJo-S
Joined Jan 3, 2026
576
3 options for 24VAC
The reason for the 1Ndiode is because the LED will not stand much more than 5V reverse. A quarter watt resistor will be too close to its max rating. Better to size up to prevent premature circuit failure. 1W is advised.
Notice in both posts I've left off the polarity. You should know that yourself. (Option 3) The 1Ndoide will block the reverse current and protect the LED.
EDIT: Just noticed that you want a blue LED for the 24VAC circuit. (see post#12) I cut-n-pasted for the 24VAC circuit without considering the Vf for a common blue LED. Values will change a little. The current will be slightly lower depending on the actual Vf of the blue LED.
B-JoJo-S
Joined Jan 3, 2026
576
Actually, the third option has to consider both the LED Vf and the 1Ndiode (typically 0.6Vf).
Assuming 3.0Vf for the blue LED:
(24VAC-3Vf-0.6Vf)÷1000Ω=20.4mA
24V x 20.4mA = 490mW (very close to max for 1/2W resistor. Go with 1W)
EDIT: Correcting the drawing for post #11.
EDIT #2: OK, I'm done messing with these drawings.
Externet
Joined Nov 29, 2005
2,678
Limit the current specified for the antiparalleled leds with a resistor or a capacitor of proper value. Each LED shown can be a series of maaany.
ronsimpson
Joined Oct 7, 2019
4,845
Post 11 picture 3 there should be 1/2 as much power loss in the resistor.
When a LED is rated for 20mA you don't have to run it at 20mA or anywhere near 20mA.
B-JoJo-S
Joined Jan 3, 2026
576
Yes, true. The user should decide what current they want to run it at and calculate for the correct resistance.
At 490mW that's very close to the max for a 1/2 watt resistor. No head room. Since they don't make 3/4W resistors, at least not that I've ever heard of, going with a 1W seems prudent.
B-JoJo-S
Joined Jan 3, 2026
576
I was trying to point out that current only flows 50% of the time in this example.
Yet another reason why I never became an engineer. Yes, you're right. I hadn't thought of that. I may know what AC is but I don't always account for its behavior. Thank you for pointing that out.
There you go Kim Sleep. A good reason why hearing from many others is a good idea. Some boob may give you inaccurate information. Ron is right. In the third example on post #11 and post #17 current will flow only half the time, resulting in half the heating of the resistor. In the first two examples where there are two LED's or one LED and one diode current will flow in both directions. In those cases the 1W resistor is advisable.
