Why power supply don't output power?
SimoneT20
Joined Nov 9, 2016
25
Black and green are connected together and fans are off. From refrig comes out three sets of red and black wires. One set for small fan, big fan and peltier. All should be connected correctly.
AlbertHall
Joined Jun 4, 2014
12,629
Do you get voltage on the yellow wires without the fridge connected?
Do you get voltage on the other outputs, e.g. orange wires (3.3V
AlbertHall
Joined Jun 4, 2014
12,629
I haven't come across this but is it possible that PS_ON should be grounded after the PSU is turned on (i.e. not connected when power is applied to the PSU)?
R!f@@
Joined Apr 2, 2009
10,004
Nope.
When I test them after repair, I sometimes ground PS-ON and power up.
The things is the main PSU will come online after stby is ON, so it's not a problem.
AlbertHall
Joined Jun 4, 2014
12,629
Nope.
OK. I've never tried powering up with PS_ON grounded so I ws just wondering if that was the problem.
R!f@@
Joined Apr 2, 2009
10,004
Nope, it's not a problem.
Could be the loading is too much or not balanced to a minimum required value on 12V and 3.3V
R!f@@
Joined Apr 2, 2009
10,004
OP should connect all black ( or 2 blacks ) and PS-ON together, serves the fridge GND.
Connect all yellows together, serves as the fridge +12V
The PSU should start as power is applied. PSU fan should run.
SimoneT20
Joined Nov 9, 2016
25
Okay. I have now tried few things and above don't work but if i connect 2 blacks to refrig ground and 2 yellows to refrig +12v and then turn power supply on and then connect PS-ON to blacks then all 3 fans try to move but move only 1cm. Nothing else happens.
AlbertHall
Joined Jun 4, 2014
12,629
That indicates the main supply is tripping out.
Assuming that the fridge needs less than 30A (does it?) and all wires other than those you mention are unconnected then try this with the fridge not connected to the PSU.
SimoneT20
Joined Nov 9, 2016
25
Specs say this refrig requires 12V 6A.
All other wires was unconnected.
I now connected 2 black wires together and 2 yellow wires together but did not connect these to refrig and then turned power supply on and nothing happened. Then connected green to black and power supply fan tried to move again.
R!f@@
Joined Apr 2, 2009
10,004
Check if the PSU runs just by connecting PS-ON to GND with everything else disconnected.
If it does not, scrap it and find another
SimoneT20
Joined Nov 9, 2016
25
Is it possible to use car battery charger? Product like this: box says 12V / 4,2A but box has also big 6A and spec says: 6A 12V 230V ?-45Ah. What’s the difference between 6A and 4,2A. Refrig needs 6A.
Or can i wire two regular 12V 3A power sources together? Similar ones which comes with HDD…? Thanks
