AlbertHall
- Joined Jun 4, 2014
- 12,629
What does your meter read if connected between +5VSB (purple wire) and COM?
Do you get voltage on the yellow wires without the fridge connected?Black and green are connected together and fans are off. From refrig comes out three sets of red and black wires. One set for small fan, big fan and peltier. All should be connected correctly.
Yes, indeed.PS ON should be at GND if the PSU is to be ON.
OK. I've never tried powering up with PS_ON grounded so I ws just wondering if that was the problem.Nope.
When I test them after repair, I sometimes ground PS-ON and power up.
The things is the main PSU will come online after stby is ON, so it's not a problem.
Okay. I have now tried few things and above don't work but if i connect 2 blacks to refrig ground and 2 yellows to refrig +12v and then turn power supply on and then connect PS-ON to blacks then all 3 fans try to move but move only 1cm. Nothing else happens.OP should connect all black ( or 2 blacks ) and PS-ON together, serves the fridge GND.
Connect all yellows together, serves as the fridge +12V
The PSU should start as power is applied. PSU fan should run.
That indicates the main supply is tripping out.Okay. I have now tried few things and above don't work but if i connect 2 blacks to refrig ground and 2 yellows to refrig +12v and then turn power supply on and then connect PS-ON to blacks then all 3 fans try to move but move only 1cm. Nothing else happens.
