What do you think about this project?
Lore_1147
Joined Feb 2, 2025
1
Smart, long-range weather station
Strenghts:
Fully configurable
Configuration packages for different sectors
Local web server when wifi is not avaliable
Wide range of operation
High precision
What do you think?
32,883
Strenghts:
Fully configurable
High precision
What do you think?
I think it's a bunch of meaningless technobabble.
MisterBill2
Joined Jan 23, 2018
27,584
OK, it might be high accuracy or high stability, or even "high resolution", but "high precision" is meaningless, although it sounds good to a lot of folks. The display in post #7 has a rather high resolution, as we can see three digits and four digits of displayed values. Accuracy is not so obvious, it will require knowing the actual values to determine accuracy.
Ya’akov
Joined Jan 27, 2019
10,241
Welcome to AAC.
Unfortunately it is impossible to tell what you intend to do from your description. On the one hand, this is mostly a solved problem, with many products on the market incorporating various features you mentioned. On the other hand, you might have a goal that overcomes this objection. Since this device mostly already exists, you will have to explain your motivation in replicating it.
It could be that you just want to build something, and that is the benefit of replication. Or, it could be that you are aware of the current offerings and intend to—in some way—differentiate your version from those. Or, it could be that you want to focus on something like using open source hardware and code. Or… something else.
But, to be able to answer your question about “what we think” you will have to explain how your project will be different than the myriad options already available. What would your weather station do that others can’t? Why is that important? Who is this target user for this device? How will your changes make something worth looking at?
Tonyr1084
Joined Sep 24, 2015
9,744
What do you think?
Two things:
First, I think I want to build an electric car (full size, not a model) that runs on a single 9V battery. And can travel thousands of miles on just one battery.
Second, I think this post is nonsense.
Sorry - you asked what I think. We get people coming here just to be heard.
