Gas Detector Project
ericgibbs
Joined Jan 29, 2010
21,582
hi johny,
The BC557 is used to invert the signal from Sensor to the 555.
Can you measure the amplitude/level of the signal coming out of the Sensor?
It should be possible to use the LM358 to replace the BC557 as the inverter.
E
LesJones
Joined Jan 8, 2017
4,544
As there are 2 outputs from the gas sensor with one marked D0 and the other marked A0 I suspect that D0 is digital and A0 is analogue. I think D0 just switches state a some preset level so adding a pot and opamp would not let you change the level that the LED switches on. The part number of the sensor or the datasheet would tell us if this theory is correct.
Les.
AnalogKid
Joined Aug 1, 2013
12,280
Your question is not at all clear. It sounds like what you want to do is change the circuit so that the detection level for the gas is adjustable. It that correct, or do you want an adjustable ON time for the LED?
Please post a schematic that is your best guess at what you want, so we can provide some steering.
ak
