H-bridge Motor Driver as Project
realabrarzahin
Joined Jun 11, 2026
8
I'm a CSE undergrad (1st year). As a project for our Electronics Eng. course I decided to make a H-bridge motor driver and here is the schematic ( i actually donno what the Electrical Engineering terms are)
I just want to know is there any problem in the current design here... do mind that it's for our project submission purpose and not for industrial use..
Thank you for reviewing a noob's project XD
ronsimpson
Joined Oct 7, 2019
4,851
1N4148 diode is low current.
At the moment the MOSFETs on the left side are off. OK But the MOSFETs on the right side are both on. Not good.
BobTPH
Joined Jun 5, 2013
11,665
The glaring problem is that there are no inputs shown. How do you expect it to control anything without inputs?
Alec_t
Joined Sep 17, 2013
15,160
Q2 is upside down.
The IRFZ44N needs a Vgs of ~10V to switch the FET fully on.
Is the motor intended to be PWM-controlled?
35,268
You have 4 input pins shown, PIN1-PIN4.
That gives 16 possible combinations. Reduce that to 4 combinations using only 2 inputs.
Draw the truth-table of operation for 2 inputs.
panic mode
Joined Oct 10, 2011
5,413
is this meant to work only on 12V? if using wider supply you will want to add some limiting on Vgs. as stated before 1N4148 is a signal diode. what is the load this bridge is supposed to drive? It makes ZERO sense to use 50A mosfet and pad it with 0.2A diode. what is the frequency you plan to run this on? why not have all 4 inputs work the same way - input HIGH turns ON matching mosfet? then you can tie inputs on same side together...
realabrarzahin
Joined Jun 11, 2026
8
Q2 is upside down.
Yes it is intended to be PWM controlled.
And I figured it out that it need actually 10V to turn it fully on. I actually have these in hand currently and therefore using for design. But i agree that logic level IC's are better here.
Thanks!
realabrarzahin
Joined Jun 11, 2026
8
1. No it meant to be varying volt between say 6-20V
2. 50A mosfets are in use here because I have those in my hand. But it will be kind if you suggest proper MOSFETs.
3. About the frequency I didn't understand.. I mean frequency of what?
4. And will think your last point
Thank You!!!!
ronsimpson
Joined Oct 7, 2019
4,851
Here is a link. I searched for 50 to 100V diodes and 1A to 6A and fast (below 50nS).
digikey
Most venders have a search engine to help. You can choose SMD or through hole and many choices.
Futurist
Joined Apr 8, 2025
950
I have a general question about PWM and DC motors. I read that the switching frequency is sometimes above 20 KHz to make any mechanical whining sound inaudible.
Is that true? Isn't a sharp square wave across an inductive load going to cause some nasty voltage spikes?
ronsimpson
Joined Oct 7, 2019
4,851
If you drive the motor directly with ac the frequency should be above 20khz. If you add a LC filter so the motor mostly sees dc then the frequency is not important.
