Good morning gentlemen and ladies,
I'm happy to report that over the last couple days I've been able to work rigorously on the WFC. I built the circuit shown under the guidelines of Wook, IBLC and others. I'm waiting on a delivery from jameco for the 10nf caps, 10k pots, and transistors/diodes needed to build a better fet driver.
Question 1, is there any way to get LTSpice (or another prog) to tell you the theoretical frequency of the 555 oscillator?
2- At present, I've used the closest values I had to what was called for. I'm getting good square wave pulse trains although the max frequency and duty cycle are very low, I think because of the newly raised values of R7-R10?
3-The MOSFET gate does not seem to open all the way. When viewed on scope the wave forms are formidably square yet only at max of about 5V. I tried with and w/o D2, no effect. I connected a speaker to the fet drain and negative terminal, and the circuit dies, 0v.
I'm guessing that the source current of pin 3 on the second 555 is not high enough to completely open the gate, and I'll have to wait and build the driver. Any ideas?
