Indeed, how accurate is this program?Beware though SPICE might be lying.
What is this ringing? I notice it too coming from power supplies when directly connected to the cell... 18V 4.9 amp, 24V .83 amps, etc. they change pitch with changes in the water. I can hear the pitch change when I adjust frequency as well.You really don't want a zero resistance path to a MOSFET gate anyway, because it will "ring" at very high frequency
I appreciate your concern. I'll post before attempting anything drastic.This is not a good idea for you to try at this point. My concern is your safety.
I don't have much bucks, but I do have a 250 watt compaq desktop power supply.with an ATX form factor power supply, you can make a decent bench supply out of it for a few bucks
Tap water currently, ideally distilled, no electrolyte. The charging chokes and oxide coating on the electrodes are to prevent "electron leakage, allowing voltage to take over and perform the work" This has been a serious point of argument with traditional physicists. Here is an article suggested by a friend on the work voltage can perform http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elewor.htmlK, wait a sec - are you using pure distilled water, tap water, or are you using an electrolyte solution?
It has it's limitations. For example, you can stress a component far beyond what "real world" limitations would be. In eblc1388's simulation with the 555, it's output is sourcing/sinking in excess of 450mA, which wouldn't work in the real world without letting the smoke out of the 555. You have to examine what the simulation is reporting, and correct situations like that where components would be subjected to excessive stresses; in this case the solution would be to increase the value of resistance between the output of the 555 timer and the gate to reduce peak current.Indeed, how accurate is this program?
The ringing I'm talking about is at a very high frequency that you wouldn't be able to hear; in the 100kHz to 20MHz range.What is this ringing? I notice it too coming from power supplies when directly connected to the cell... 18V 4.9 amp, 24V .83 amps, etc. they change pitch with changes in the water. I can hear the pitch change when I adjust frequency as well.
Safety is paramount here. Fiddling around with high voltage near water is generally not conducive to good health for n00b's.I appreciate your concern. I'll post before attempting anything drastic.
If it's an ATX form factor supply, you can convert it pretty inexpensively.I don't have much bucks, but I do have a 250 watt compaq desktop power supply.
Already did that before I saw your post. The result is about the same:OK, but now you're loading the single 555's output by both gate circuits.
Clone your 555 circuit, and re-label the nets 555out1 and 555out2.
I was joking when I said SPICE was lying. I picked that up from what Bob Pease have always said and I agree with him.Indeed, how accurate is this program?
What was the incorrect configuration, and what did you do to fix it?Ok I fixed the circuit... I am actually getting gated square wave pulse trains now YAY! Thanks
The ATX supplies are switchers. They won't regulate properly unless they have a load on the +5v supply. If you're desperate/in a hurry, Radio Shack sells a pair of 10 Ohm, 10W power resistors in a bubble pack for around $2. If a store is close by, it may actually be cheaper to buy them there than ordering them online and paying shipping charges.I'm going to begin work on the MOSFET driver, but first, to convert the ATX supply to a bench top power source.
To build the power supply I apparently need a 10ohm, >10W resistor to connect the +5v (red) and 0v (black) output wires together (not sure why)
I used a miniature SPDT switch on mine. A black wire goes to the common terminal (center), the green power ON lead goes to the lower terminal, and I have a yellow LED connected to the upper terminal of the switch via a 330 Ohm resistor to the violet (purple) standby +5V that tells me the supply has line power connected. When the supply is turned ON, the standby light goes out; but I have a couple of green LEDs on +3.3v and +5v to indicate that the voltages have come up. There was no point in unnecessarily loading the +12v, -12v and -5v supplies with an LED or complicating the assembly.Then, the green (power ON) connects to black (0v) via a switch.
Oddly enough, RadioShack might be the least expensive place to get binding posts. Keep in mind, the Radio Shack binding posts are rated for a maximum of 10A, and your +5V supply can likely output more than twice that. I doubled up on my +5v and +3.3v posts; each has a matching ground post.As for the MOSFET driver circuit, I don't have the 1N5817 Diode or the 2N2907 transistor, and I need some binding posts for the power supply. Should I be able to find these at radioshack or am I placing another order with Jameco?
It was a careless mistake, I forgot to hook up pin#1 to ground on the second oscillator, so it was completely disabled. Now the circuit works great! I was curious though, could you explain how the capacitor values at pin5 and at pin6/2 affect the output?What was the incorrect configuration, and what did you do to fix it?
Are these the same as zener diodes? Why is a lower Vf better?The idea of using these 1A Shottky diodes is that it allows for a very fast charge of the MOSFET's gate, with a very low Vf, and also they turn off VERY quickly. You might think you could use a 1N4000 series, but those are extremely slow by comparison to switch on and off, and have three times the Vf.
Good that you found it. Little things like that can drive one bonkers.It was a careless mistake, I forgot to hook up pin#1 to ground on the second oscillator, so it was completely disabled. Now the circuit works great!
The 10nF cap from pin 5 to ground helps to keep the Control Voltage stable. Without a cap there, the frequency output will be less stable, particularly if there is noise on Vcc. Look in National Semiconductor's datasheet for the LM555 at the internal schematic on page 1, and you'll see that pin 5 is connected to the upper limit (2/3 VCC) of the threshold voltage divider circuit (three 5k resistors in series from Vcc to GND).I was curious though, could you explain how the capacitor values at pin5 and at pin6/2 affect the output?
No, Schottky diodes are not the same as Zener diodes.Are these the same as zener diodes? Why is a lower Vf better?
I understand. But, the more you update it, the easier it will be - because you will become more proficient, and by updating it more often, you'll have fewer changes to make.The website is still in progress, I've been making frequent changes but it's a lot of work to update. I'm hoping once I update it a few times the process gets easier and I can use it as a journal and reference tool. I will also be redrawing the circuit with component labels and the new values
Ahh, do you mean eblc1388's latest schematic?-- currently I have R7/R9 at 470 ohms, R8/R10 at 1.5k ohms, do you recommend 1.5k and 6.8k as your latest schematic shows?
I see. It's really best to show waveforms referenced to ground, unless it's special circumstances like the Vgs of a P-channel MOSFET; in that case your reference point would be the source terminal of the MOSFET.The scope shots you see are actually inverted. I had the negative probe hooked to the 555 output. They are simply to show the max and min frequency of one 555 chip given different R values.
You're correct in how you're reading the ceramic cap values.I'm having a hard time understanding capacitor values. I bought a random assorted collection from RS and organized them into a nice little box with dividers. The numbers of the ceramic disc caps I have are
7
10
15
68
101
151
221
561
From what I've read, 1 = 1 pF, 10 = 10 pF, 101 = 100 pF, 221 = 220 pF, etc. Maybe I'm way off...
I was just getting ready to order some stuff from jameco.The MOSFETs that you've salvaged [IRF3710] are reasonably good for your application, but they do have an Achilles' heel, and that is their relatively large gate charge requirement.
Why don't you look in LTSpice?Is there a particular mosfet you would recommend, with low ON resistance, low gate charge requirement, and high voltage/current capacity? Prefer around 120V / 10amp rating. I'll be ordering very soon!
No. 110V/220V transformers were designed to run on a 60Hz sinewave, where auto ignition coils are "broadband".Ok, next problem.
I want to apply high volts to the submerged electrodes. Can I use the auto ignition coil in series with the secondary winding of an isolated 110V/220V step up transformer?
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
