Yes, you are correct.I will have to actually reverse the LED too since it does have a positive and negative side, right?
I don't know where you are coming from, the identity of LED's were not in question here. The issue was the SSR was hooked to the transistor with the transistor as a switch and the LED/resistor was hooked to the transistor as a voltage follower, which was causing a closed circuit to the SSR when the transistor was off due to the resistor going to ground.I think the diodes with the lightning bolts are LED's.
